Where do I start with OPAL?
If you are just getting started with Observe, you will notice, right away, that we have a powerful language that is used within our platform called OPAL. If you are looking to start learning about OPAL, a great place to start is OPAL 101. This will give you a jump start on your journey to becoming an observability master!
As you learn along the way, you may need a few hints or tips. Don’t forget to consult your AI partner, o11y, who can give you tips and answers to your OPAL questions. o11y is in the lower left of your menu.
And finally, as you hone your skills, you might want to consult the OPAL Reference or the Performance Cookbook to keep your worksheets and dashboards running smoothly.
