Overview
When using the Terraform Observe provider to manage resources in Observe, you may encounter an error similar to:
Error: failed to create monitor: Post "https://<ID>.observeinc.com/v1/meta": net/http: request canceled (Client.Timeout exceeded while awaiting headers)
This error typically occurs when the HTTP client in the Terraform provider times out while waiting for a response from the Observe API. This can happen due to network latency, large data transfers, or slow API responses. To address this, you can configure the http_client_timeout parameter in the Observe provider block to increase the timeout duration.
Solution: Configuring http_client_timeout
The http_client_timeout parameter in the Terraform observe provider specifies the maximum time the HTTP client waits for a response from the Observe API. By default, this value may be too low for certain operations, especially those involving large datasets or complex queries. Setting it to a higher value, such as 10m (10 minutes), can help resolve the timeout error.
Step-by-Step Instructions
Locate or Create the Provider Block: In your Terraform configuration (e.g.,
main.tforprovider.tf), find the provider “observe” block. If it doesn’t exist, add one. -
Set the
http_client_timeoutParameter: Add or update thehttp_client_timeoutattribute within the observe provider block. Specify the timeout duration in a format like 10m (10 minutes).Example configuration:
provider "observe" { customer = "<your-customer-id>" endpoint = "https://<your-observe-instance>.observeinc.com" token = "<your-api-token>" http_client_timeout = "10m" }-
Replace , , and with your Observe account details.
The
http_client_timeoutvalue of 10m sets a 10-minute timeout, which is sufficient for most operations.
