Observe-Agent Deploying Tip While deploying using Gitops Tools
Important: Environment Variable Overrides in Observe Agent Deployments
When deploying the Observe Agent through automation tools such as GitOps, ArgoCD, Spinnaker, or CI/CD pipelines, pay close attention to how environment variables (extraEnvs) are defined.
:light_bulb: Why This Matters
Kubernetes merges environment variables defined in the container spec in order, but Helm (and most templating tools) treats extraEnvs as a complete list.
If you redefine extraEnvs in your custom values file or through an overlay, you override the entire default set of environment variables shipped with the Observe Agent chart — not just the ones you specify.
That means:
Setting one custom environment variable without re-including the defaults will cause the rest (like OBSERVE_CLUSTER_NAME, K8S_NODE_NAME, etc.) to be lost.
:cross_mark: Example of a Problem
If you define only:
extraEnvs:
  - name: TOKEN
    valueFrom:
      secretKeyRef:
        key: OBSERVE_TOKEN
Then all other default variables (like OBSERVE_CLUSTER_NAME, OBSERVE_CLUSTER_UID, etc.) are dropped.
Result:
  • The agent loses cluster identity context.
  • Metadata enrichment fails.
  • Metrics and logs may appear without proper tags in Observe.
:white_check_mark: Correct Way — Merge All Required Variables
Always include the full default environment variable set when customizing extraEnvs.
extraEnvs:
  - name: TOKEN
    valueFrom:
      secretKeyRef:
        key: OBSERVE_TOKEN
        optional: false
  - name: OBSERVE_CLUSTER_NAME
    valueFrom:
      configMapKeyRef:
        key: name
  - name: OBSERVE_CLUSTER_UID
    valueFrom:
      configMapKeyRef:
        key: id
  - name: K8S_NODE_NAME
    valueFrom:
      fieldRef:
        fieldPath: spec.nodeName
  - name: K8S_NODE_IP
    valueFrom:
      fieldRef:
        fieldPath: status.hostIP
If you need to add custom variables (for example, CUSTOM_ENV=production), append them to this list — never replace it.
:brain: Why GitOps and CD Tools Make This Easy to Miss
When using GitOps or declarative tools (like ArgoCD, Spinnaker, Flux, or Terraform Helm releases):
  • The tool applies your provided values file exactly as written.
  • It doesn’t “merge” nested lists such as extraEnvs; it replaces them entirely.
  • So a partial override will wipe out Helm’s defaults silently.
:white_check_mark: Best Practice Summary
Recommendation Description
:magnifying_glass_tilted_left: Verify all required env vars Check that all standard extraEnvs are present before deployment.
:puzzle_piece: Use complete list overrides When overriding Helm values, redefine all env vars together.
:brick: Validate post-deployment Run kubectl describe pod <agent-pod> → confirm environment variables are populated.
:locked: Keep credentials secure Reference tokens and IDs from Secrets and ConfigMaps using valueFrom.
:white_check_mark: In short:
If you redefine even one environment variable using extraEnvs, Helm will replace the entire block — not merge it.
Always include all required variables to avoid breaking cluster identification and telemetry flow.
