How to get MongoDB Atlas Prometheus Metrics into Observe
This guide walks through how to integrate MongoDB Atlas Prometheus metrics directly into Observe, using the Observe Agent’s Prometheus receiver.
:key: Prerequisites
Before beginning, make sure:
  • You have access to your MongoDB Atlas Project and its organization settings.
  • You have Prometheus integration enabled for your Atlas project.
  • You can modify your Kubernetes cluster’s configuration where the Observe Agent is deployed.
:brick: Step 1. Add Kubernetes Cluster Egress IPs to MongoDB Atlas Allowlist
MongoDB Atlas restricts Prometheus scraping to authorized IPs.
Add your Kubernetes cluster’s egress IP addresses to the Atlas allowlist:
:backhand_index_pointing_right: Follow MongoDB’s documentation:
Configure IP Access List Entries — Atlas — MongoDB Docs
Make sure to add all egress IPs used by your Observe Agent’s namespace or node pool.
:gear: Step 2. Enable Prometheus Integration in MongoDB Atlas
Enable and configure the Prometheus integration in the Atlas UI:
  1. Navigate to Project Settings → Monitoring → Prometheus.
  2. Enable the integration and generate credentials.
  3. Note the username, password, and Prometheus discovery URL provided.
Refer to MongoDB’s official documentation for detailed steps:
Integrate with Prometheus — Atlas — MongoDB Docs
:locked_with_key: Step 3. Create a Kubernetes Secret for MongoDB Credentials
Store your Atlas Prometheus credentials securely in the Observe namespace as a Kubernetes secret:
kubectl create secret generic customer-mongodb-credentials \
  --from-literal=USERNAME=INSERT_USERNAME_HERE \
  --from-literal=PASSWORD=INSERT_PASSWORD_HERE \
  -n observe
Replace INSERT_USERNAME_HERE and INSERT_PASSWORD_HERE with your Atlas credentials.
:rocket: Step 4. Configure the Observe Agent for MongoDB Metrics
Prepare a mongodb.yaml file (values.yaml) with the following configuration, updating the placeholders with your credentials and project ID.
agent:
  config:
    prometheusScraper:
      processors:
        attributes/debug_source_mongodb_prometheus:
          actions:
          - action: insert
            key: debug_source
            value: mongodb_atlas_prometheus
        batch:
          send_batch_max_size: 20480
          send_batch_size: 16384
          timeout: 1s
        memory_limiter:
          check_interval: 5s
          limit_percentage: 80
          spike_limit_percentage: 15
      receivers:
        prometheus/mongodbatlas:
          config:
            scrape_configs:
            - basic_auth:
                username: ${env:CUSTOMER_MONGODB_ATLAS_USERNAME}
                password: ${env:CUSTOMER_MONGODB_ATLAS_PASSWORD}
              http_sd_configs:
              - url: https://cloud.mongodb.com/prometheus/v1.0/groups/INSERT_GROUP_ID_HERE/discovery
                refresh_interval: 347s
                basic_auth:
              job_name: customer-mongo-metrics
              metrics_path: /metrics
              scheme: https
              scrape_interval: 300s
      service:
        pipelines:
          metrics/mongodb_atlas_metrics:
            receivers:
            - prometheus/mongodbatlas
            processors:
            - memory_limiter
            - batch
            - attributes/debug_source_mongodb_prometheus
            exporters:
            - prometheusremotewrite/observe
:counterclockwise_arrows_button: Step 5. Upgrade the Observe Agent Helm Chart
Apply the updated configuration to your Observe Agent using Helm:
helm upgrade observe-agent observe/agent -n observe -f mongodb.yaml
This will deploy the new Prometheus receiver for MongoDB Atlas metrics.
:bar_chart: Step 6. Create a Dedicated Dataset for MongoDB Metrics
In Observe:
  1. Navigate to Datasets → Create Dataset.
  2. Use the prometheus dataset as your base.
  3. Filter by debug_source = "mongodb_atlas_prometheus" to isolate MongoDB Atlas metrics.
Name this dataset something like MongoDB Atlas Metrics.
