How to add correlations tags to OTEL Logs Direct Write Dataset
Adding Correlation Tags to the OTEL Logs Direct Write Dataset
The OTEL Logs Direct Write dataset cannot be directly edited. To add correlation tags, follow these steps:
  1. Locate the dataset in the Observe interface.
  1. Click the menu (down arrow) to the right of the dataset name.
  2. From the dropdown menu, select Edit dataset definition
  1. In the edit screen, you can now add or modify Correlation tags as needed.
