Creating Dependent Parameters for a Dashboard
Dependent Parameters for Dashboards
If you are looking for a way to create dependent parameters for dropdowns, this might be the right topic for you. By combining a reference table with parameters, you can ensure that the parameters are tied together in a way to create dependent parameters.
Step-by-Step Guide
In this example, we will use sample data with City, State, Country, Latitude, and Longitude to create a functioning example.
  1. Use the sample data to create a reference table. Name the reference table city_state_country_lat_lon
    City,State,Country,Latitude,Longitude
    New York City,New York,United States,40.7128,-74.0060
    Buffalo,New York,United States,42.8864,-78.8784
    Los Angeles,California,United States,34.0522,-118.2437
    San Francisco,California,United States,37.7749,-122.4194
    Miami,Florida,United States,25.7617,-80.1918
    Toronto,Ontario,Canada,43.6532,-79.3832
    Montreal,Quebec,Canada,45.5017,-73.5673
    Vancouver,British Columbia,Canada,49.2827,-123.1207
    London,England,United Kingdom,51.5074,-0.1278
    Manchester,England,United Kingdom,53.4808,-2.2426
    Edinburgh,Scotland,United Kingdom,55.9533,-3.1883
    Paris,Île-de-France,France,48.8566,2.3522
    Marseille,Provence-Alpes-Côte d’Azur,France,43.2965,5.3698
    Berlin,Berlin,Germany,52.5200,13.4050
    Munich,Bavaria,Germany,48.1351,11.5820
    Sydney,New South Wales,Australia,-33.8688,151.2093
    Melbourne,Victoria,Australia,-37.8136,144.9631
    Rio de Janeiro,Rio de Janeiro,Brazil,-22.9068,-43.1729
    São Paulo,São Paulo,Brazil,-23.5505,-46.6333
    Tokyo,Tokyo,Japan,35.6895,139.6917
    Osaka,Osaka,Japan,34.6937,135.5023
    Beijing,Beijing,China,39.9042,116.4074
    Shanghai,Shanghai,China,31.2304,121.4737
    Delhi,National Capital Territory of Delhi,India,28.7041,77.1025
    Mumbai,Maharashtra,India,19.0760,72.8777
    1. Save the sample data to a file.
    2. Choose Data and Integrations → Add Data
    3. Choose CSV File where you have saved the sample data
    4. Use the name city_state_country_lat_lon for the Reference Table and choose City and State for the primary keys
  2. Create a new Dashboard
  3. Add a Card by Selecting Add Cards and choose Table → Dataset
  4. Choose your reference table you just created, name the card parameter_data and then click Apply
  5. Next, we want to start creating the first parameter. Click Add Parameter → Single-value . Click Save and Select Cards. Select the parameter_data card and map to the City column.
  6. Next we will create a parameter for state. Choose Add Parameter → Single-value. Click the Save and Select Cards. Select the parameter_data card and map to the State column.
  7. Finally, we will add the parameter for country. Choose Add Parameter → Single-value. Click the Save and Select Cards. Select the parameter_data card and map to the Country column.
  8. Now, to visualize your results. Choose Add to Dashboard → Visualizations → Dataset . Choose the source as a Query and choose the parameter_data card. Select Geographic Map for the Chart type. You will need to select the Latitude and Longitude Columns in the Chart Settings.
  9. Once you have clicked Apply, you will notice that as you change the parameters, the parameter_data table’s possible values change. The map should also update according to your selections.
  10. Although it is nice, for this example, to see the Tabular data, just know that you can also hide the card so that only the parameters and the map are showing. You can hide the parameter_data by clicking Manage All Queries and then click on the 3 dots (…) next to the parameter_data card. Choose Hide from dashboard. See the two examples below.
Hopefully this topic gives you an idea of how you can create dependencies between parameters that can drive your dashboard!
